1998 Chrysler Cirrus crackling noise
110,000 MILES • 6 CYL • FWD • AUTOMATIC
AGAGUILARJR
there's a crackling noise that you can hear upon starting and right after slightly stepping on the gas. it lasts for a few seconds and stops. The noise is present when the car is parked and and the engine is running. I stepped on the gas and after i let go of my foot then there's the noise. its like a crackling noise that you can hear somewhere around the engine itself. maybe like a loose fan or belt. but the belts that i see seems not be loose anyhow. so it might be something inside.
Nov 24, 2009 at 3:54 AM
  • 110,248 POSTS
I need you to check something. Take a rubber mallot and tap on the exhaust system to see if you can recreate the sound. It could be a loose heat shield or an internally loose catylatic converter.
Let me know what you find.
Dec 7, 2009 at 1:44 PM
