computer reset after battery change?
1995 CHRYSLER CIRRUS
157,000 MILES • 6 CYL • FWD • AUTOMATIC
JANAESEWELL
my car cuts off on me a lot and normally restarts today it cut off cant restart before that happened my diagnostic system (key ignition reading codes) gave me a code 12 battery disconnect recently if the computer on my car was not reset will that cause it to stall or shut off if so how do i reset computer
Sep 1, 2009 at 11:09 PM
  • 110,244 POSTS
Was the battery disconnected? It sounds like you may have a intermittent short in the battery here is a test to help you confirm the issue.
Cheers
Sep 2, 2009 at 3:49 AM
JANAESEWELL
Man you are good that was the problem thank you so much I cant believe this site is free god bless you guys.
Sep 4, 2009 at 3:09 AM
