1990 Chrysler Cirrus Alternator
NICHOMA
  • 1990 CHRYSLER CIRRUS
Interior problem
1990 Chrysler Cirrus 6 cyl Front Wheel Drive Automatic
How do I know if the alternator is going out?
Tuesday, October 21st, 2008 AT 6:48 PM
ZACKMAN
  • 4,202 POSTS
You will see battery light and (sometimes) brake light on your dash when the engine is running.
Exactly, what your is your car? There is no such thing as 1990 Chrysler Cirrus.
Tuesday, October 21st, 2008 AT 8:30 PM
NICHOMA
My car is a New Yorker or Fifth Avenue. The check engine light comes on every other or two days and the car will jerk as if it wants to die out. If I come to a complete stop after that, the car dies out but starts up right away with no problem. This started last Monday, then it was fine Tuesday and Wednesday and did it again Thursday. Then it was fine until Sunday. It has not done that since then.
Is there any other way to check if it's the alternator?
Wednesday, October 22nd, 2008 AT 10:43 AM
ZACKMAN
  • 4,202 POSTS
I don't believe that it is your alternator. Bad alternator does not send signal for your check engine light to come on. If the battery light in the gauge cluster is not on, your alternator is OK.
You can go to any auto parts store (Autozone, Checkers, Kragen, Advance, whichever in your area), they can test your alternator for free. Or you can do this yourself. You have to have a voltmeter, though. With the engine running, touch the test probes to your battery. If it is showing more than 13 but less than 15.9 volts, your alternator is good.
Wednesday, October 22nd, 2008 AT 8:21 PM
NICHOMA
I will do that, thank you so much for your input.
Thursday, October 23rd, 2008 AT 10:12 AM
