OIL PRESSURE SWITCH
TREYWILL
  • 2006 CHRYSLER 300
  • 6 CYL
  • 77,000 MILES
Where is the oil pressure switch.I'm going to replace mine.
Friday, May 7th, 2010 AT 2:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Oil pressure sensor is on right front of engine or lower right front of engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Friday, May 7th, 2010 AT 2:50 PM
ROBOVEGI
  • 2006 CHRYSLER 300
Engine Performance problem
2006 Chrysler 300 6 cyl Two Wheel Drive Automatic
I am installing an after market oil pressure gage.I need to know exactly where on my 3.5 litre engine are the locations of the oil pressure ports so I can choose the most convienent one to install the sending unit.
Your giving me wrong info. My engine is the 3.5 litre not 2.7. Let me know where I can tap into to place my oil pressure sending unit. If there is more than one location I want to know that to so I can have more options. Rob O.
Wednesday, July 17th, 2019 AT 1:47 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Oil pressure switch location right side engine.
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_143.jpg
ROBOVEGI
[quote="Docfixit"]Oil pressure switch location right side engine.
[img]
You guys are giving me the wrong info. You have my vehical type and engine size mixed up. I have an 2006 Chrysler 300, 3.5 litre engine. I am installing a after market oil pressure gage. I want to know all available oil ports I can tap into, including where the oil press switch is. Im hoping to not use the oil pressure switch port. Rob O.
ROBOVEGI
Im afraid you guys are getting things mixed up, so I will start again. My car is a 2006 Chrysler 300 with a 3.5 litre engine. What I need to know is where are all of the oil press ports located on this engine? I want to tap into one to install an after market oil press gage. I would rather not use the oil pressure swiitch port unless that is recomended. I dont want to mistakenly pull a water plug. Rob O.
DOCFIXIT
  • 18,828 POSTS
Hi
When pluged in info used Chry 300 which only comes with 2.7 that year a 300,300C,300 Limited,300SRT-8 and 300 Touring where produced.
You have a 300 Limited switch is # 1 above oil filter.
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_144.jpg
That is only port to oil galley need and adapter to T off and add pressure guage and keep sensor .
ZJYYMTGT126
  • 2005 CHRYSLER 300
My car is 5.7L and V8. Recently the oil pressure sensor(switch) is bad. The old part number is 56044777AA, and it has two connections. But it is said to be superseded by 5149062AA, which has three connections. I was wondering are they actually interchangeable? Could I use the new one to fix my car? Thank you for your help!
HMAC300
  • 48,601 POSTS
If there are only two wires then it should have two wires. I would recheck your part number they may be looking up wrong engine on list.
ZJYYMTGT126
It seems like there is nowhere to buy the old part. Could you please tell me what I should do so that I can have my car fixed? I will appreciate for your help!
HMAC300
  • 48,601 POSTS
If you go to an auto parts store or the dealer I am sure they will know what is different there are no TSB's talking about a switch change which there would be if this were the case. Try a dealer I am sure they will have something on this. I have no idea how the hook up is on the three way switch so cannot advise how to hook it up.
HMAC300
  • 48,601 POSTS
I just looked on the wiring chart and the oil pressure sensor is a three wire connector. However, the oil temperature sensor is a two way wire, you are looking for the wrong one or have told the counter person the wrong sensor.
DOUGLAS CONNER
What causes my Chrysler 300-C to hesitate? I have changed the spark plugs, coil, wiring. It is a 2005. Also, my code is saying that my oil pressure sensor. Help me please.
STEVE W.
  • 13,866 POSTS
Douglas, welcome to 2carpros. Would you please use this link to ask this as a new question, please also add any information about the code like the number, what the vehicle is doing and anything that has been tried. Thank you.
NESSALEWIL
  • 2005 CHRYSLER 300
  • 6 CYL
  • 132,661 MILES
How to replace oil sending unit on 2005 chrysler 300 V6 2.7L engine
  • 110,047 POSTS
The oil sending unit just screws out. Remove the wiring to it first, and then using a ratchet, unscrew it. Note: Because of the odd head on it, a special socket is needed. When you purchase the switch, look at it to confirm you have a tool that will work. If you don't, the parts store will most likely have the socket you need.
Wednesday, July 17th, 2019 AT 1:48 PM (Merged)
NESSALEWIL
I'm having trouble locating the sending unit on the engine block the manual says it should be on the left rear side. The diagram is not very helpful.
