2006 Chrysler 300 LOUD NOISE COMING FROM STEERING COLUMN ON
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADAMGLEZ
The car makes a loud intermitent noise coming from the steering column for about 10 seconds, only when the car is started, then it disappears and the car drives normal and everything works well.
If i turn off the car and turn it on again it will do it again!
can you please help.
Thank you!
Adam.
Jan 17, 2010 at 6:12 AM
ERNEST CLARK
  • 1,730 POSTS
You'll have to describe the noise before I can answer the question.
And does it only make this noise when you turn the wheel, or not? Can you be absolutely sure it's coming from the steering wheel and not the dash or instrument cluster?
Jan 19, 2010 at 12:43 AM
