2001 Chrysler 300 Fog lights
2001 CHRYSLER 300
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
ESANABRIAJR
I recently replaced the fog lights on my 300m. They worked for about 5 minutes and then both simply shut off. The ligt bulb are fine. I even installed the old ones again, but nothing. I looked at the fuse box and could'nt find a specific fuse for the fog lights. There is a spot for a fog light relay but it was empty, it seems like its not supposed to be used My question then is:
Where is the fog light fuse or relay on my 2001 300m??? What else could cause for the lights to turn off?
Dec 31, 2007 at 4:40 AM
2CARPRO JACK
  • 11,533 POSTS
Fuse C in the underhood power center,then fuse 16 in the relay box at the end of the dash, that is also where the relay is for the fog lights
Jan 1, 2008 at 11:47 PM
