The switch the switch may be diffective.
Activate the passenger switch (down position) and check voltage at the VT wire to the motor.
if there is power, change the motor.
if there no power, activate the down position on the passenger window switch, check voltage at the switch where the VT wire connect the passenger window switch.
if there is power, , the wire VT may be bad.
if there no power, check the passengerswitch at the down position (1) connection.
if there power, replace the switch.
if there no power the problem may be at the VT/WT wire connecting to the passenger window switch.
sending in your email a printable version of the wiring diagram
Sunday, November 1st, 2009 AT 10:15 AM
