Unfortunately, this is not just one thing. There are a number of items that can cause this chime.
What we need is a scan tool that can go into the body control module and see if this is registering under the last chime monitor. This function is available in the OEM scan tool called WiTECH and I am not sure it is available in some of the others.
If we don't have this info then we will just be guessing. I am sure there are no codes but I have hear of this happening a couple times and one time it was the tire pressure system and the other it was the seat belt pretensioner. Clearly we don't want to guess so let me know if you can get access to this tool or a shop that has one. Thanks
Oct 3, 2019 at 12:00 PM
