Venture sputtering and backfires
KELC28
  • CHEVROLET VENTURE
Hello.I have a 1998 chev venture 3.4L with about 225,000km
I just changed the fly wheel on it, and put the motor back in, and hooked everything up. When I started it, it idles reasonable but when I give it gas it sputters and every once in a while it has small backfires. They arent loud more like a putt. Putt. And the engine doesnt seem to have much power when I got to take off. Everything worked fine on it before the fly wheel went, so I don't know whats wrong.I keep checking to see if I forgot to hook up something but theres nothing? Is there something I did wrong or what could it be?
Thanks in advance for your time
Trevor
Wednesday, May 9th, 2007 AT 12:30 PM
ROCKWOOD84
  • 103 POSTS
Are you sure you got the fuel lines hooked up right. My fuel pump went out the same way it started to sputter the back fire put a gauge in where the fuel filter is and see what the pump pressure is supposed to be 40 lbs. Pump is going to run about$320.00 and you have to drop the tank. You will need to get a set of gm quick release fitting tools about $15.00 to take the fittings loose. Good luck
Saturday, July 14th, 2007 AT 3:48 PM
