ENGINE SQUEAKING
PROLINE GURU
Noises problem 6 cyl Front Wheel Drive Automatic 84500 miles
i have a squeaking noise coming from the engine, i thought it was the serpentine belt,so i replaced that. a mechanic said it was the alternator bearings, so i replaced the alternator,but the noise returned the next day,so now i am not sure what it could be,can you help me? also, should i get my money back from the shop since it was not caused by the alternator?
Mar 26, 2009 at 4:23 AM
F4I_GUY
  • 3,302 POSTS
With the belt off, spin every pulley and listen for a grinding noise. As you spin the pulley it may feel rough and gritty as well. If it does, replace the bearing/pulley.
Mar 29, 2009 at 5:11 AM
POPPADOC
I removed the belt and it's still squealing. It only does when driving. I replaced the water pump, belt, and I took the belt off and Crunk it. It still seals when accelerating
Jul 30, 2017 at 10:32 AM
  • 55,583 POSTS
Here is a guide that will help you.
https://www.2carpros.com/articles/car-squeaking-noise
Please let us know what you find.
Cheers, Ken
Aug 1, 2017 at 3:10 AM
