2002 Chevy Venture purring
120,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEANGIE3049
my car is making a loud purring noise from the inside when i drive it. it gets louder the faster you go. the noise goes away when you make a right hand turn. i replaced all 4 tires today thinking that was the problem but it is still happening. what is wrong? i am thinking the berrings or the cv joint.
Sep 12, 2009 at 1:42 PM
  • 110,251 POSTS
It sounds like you have a bad wheel bearing. If it stops when you turn right, chances are it is the right front because in a turn, the vehicle's weight is transfered to the opposite side of the car. Thus, a right turn would add weight to the left and remove it from the right and the noise would lessen.
Dec 14, 2009 at 12:27 AM
