I took my car and a guy had a machine give me a few codes.
P1374 - 3 x reference circuit and eng clark sig. High to low res
p1811 - maximum adapt +long shift
what does all this mean?
Friday, April 24th, 2009 AT 11:01 AM
BLUELIGHTNIN6
MECHANIC
Code P1374 is for the crankshaft position sensor high-to-low resolution frequency correlation. Most likely culprit here is a faulty Crankshaft Position Sensor.
Code 1811 is a transmission fault code. Check the tranny fluid and filter.
