1997 Chevy Venture Temperature sensors
1997 CHEVROLET VENTURE
FRAAK
1997 Chevy Venture
I'm trying to debug a cooling system problem. My radiator cooling fans don't seem to be switching on when they should.
I assume that there's a temperature sensor somewhere that (through the computer?) tells the cooling fans to switch on.
Then there's obviously a sensor whose reading is being displayed on my dashboard temperature gauge.
Are these the same same ECT sensor? Or is a seperate sensor doing each of the two tasks?
Any clue where they may be located? (I believe I've found one near where the upper radiator hose meets the engine block.)
Thanks so much!
Nov 14, 2008 at 7:03 AM
The ECT sensor is located on top left side of engine. I've looked for an engine temperature gauge switch there's no listing for it
Test the ECT and thermostat
Jun 19, 2020 at 4:39 AM
FRAAK
Thanks for the quick reply!
Darn. I was hoping for seperate sensors. The dashboard gauge seems to be working perfectly. I've also checked fuses, relays, and (with a well-placed paper clip bypassing a relay) the fans themselves.
I *think* the thermostat's working fine too, but it may be worth a look.
By left, you mean driver's side, correct? Things get all reversed when I'm standing at an open hood.
By left, you mean driver's side, correct? Yes Sir-if its a transverse engine its a different story
