1997 Chevy Venture Oil pump
BHEMP1970
  • 1997 CHEVROLET VENTURE
Engine Mechanical problem
1997 Chevy Venture 6 cyl Front Wheel Drive Automatic
The lifters tick and there is a knocking. The oil level is ok on the dip stick. I can see the lifters through the oil fill hole and there is no oil splashing. Can the oil pump be removed with the engine in place?
Tuesday, March 23rd, 2010 AT 9:13 PM
REMOVAL
Remove the oil pan.
Remove the bolt attaching the oil pump to the rear crankshaft bearing cap.
Remove the oil pump and driveshaft.
Inspect the driveshaft at both ends for rounding of the corners.
Tuesday, March 23rd, 2010 AT 10:08 PM
