2005 Chevy Van Change coolant
2005 CHEVROLET VAN
JAMESBRANDEN
Engine Cooling problem
2005 Chevy Van V8 Two Wheel Drive Automatic
how do I find the drain plug for radiator
Dec 12, 2009 at 3:22 PM
MIKE H R
  • CAR REPAIR CONTRIBUTOR
  • 3,094 POSTS
some radiators have a plug on the left side bottom of the radiator. Remove plug and dra9in the radiartor, make sure you have a big enough pan to cover under the radiator to catch the antifreeze. Some radiators do not have a plug. In that case you will have to remove the bottom radiator hose. Best thing is to loosen it up some and let it drain out slowly. Again make sure there is a big enough pan to cartch all the fluid.
Dec 26, 2009 at 12:24 PM
