We bought a 2007 Uplander just less than 2 months ago.
Once a while (at least 6 times in last 2 weeks), when I step on the gas after the van comes to a full stop (stop sign or light), the engine RPM went up but the van only move so slightly (a few times won't even move).
It seems the gear is not engaged. I have to keep step on the gas to make it move. It is a scary feeling if you stuck in a major intersection.
I took it to a GM service center. But they can't find anything wrong using some kind of scanner.
They drove it for a while and it didn't happen to them. All they found is the trans. fluid level is down a little bit (about 1/4 gallon). So they top it up and that's it.
What is the cause of the problem or they just BS me?
Jan 5, 2007 at 7:43 PM
