I have a 93 Chevy Silverado Z-71 4x4 with a 5.7 V-8. It has 175000 miles on it. I lost fire, but had fuel. It was running and just shut down. After replacing the coil (which didn't fix the no fire) I tested the rest of the ignition components. All tested fine. When I put it back together I had fire but now have no fuel through the injectors. All tests show everything is good. I have fuel all the way to the thottle body. Changed the ECM since everything tested out fine. All fuses and fused links are good. Will start if you put fuel straight in the TBI. Filter has been checked, all electrical ahs been checked and test out according to the repair manual. What am I missing.
May 25, 2007 at 6:33 AM
