2002 Chevy Tracker Cranks But Won't Start
SKWIRT17
Hi! I own a 2002 Chevy Tracker with 75k miles on it. I recently had the PCV Valve and Starter replaced, along with the fuel lines. I went to start it this morning and it would turn over, but not fully engage, all instinct told me it was my Fuel Pump, so I had it towed to the dealership where the service manager was first telling me I got a bad batch of gas, now he is convinced it is the O2 sensor, now, I am just a girl, but I do know a thing or 2 about cars, and correct me if I am wrong, but I did not think that a faulty O2 sensor would kill the engine completely, just wear on the fuel economy and make the engine sputter a bit... Please help - I do not want to pay for a part that 1. I do not need and 2. Will not fix the problem.
Oct 29, 2007 at 8:17 AM
2CARPRO JACK
  • 11,533 POSTS
If the o2 sensor is completely shorted it caqn keep the car from running. Have them unplug it and see if it starts, worst it would do is set a code. That truck has a MAF sensor, I would look for any air leaks between the MAF and the throttle bore or any other vacuum leaks.
Oct 29, 2007 at 9:16 AM
Suggested Repair
Unplug the oxygen sensor and try to start the engine; a fully shorted O2 sensor can prevent running, and unplugging it should at worst set a code. Also inspect for air leaks between the MAF sensor and the throttle bore and for other vacuum leaks.
Conversation Summary
The owner of a 2002 Chevy Tracker says the engine cranks but will not start after recent PCV valve, starter, and fuel-line work. The dealer first blamed bad fuel, then an O2 sensor, which the owner doubts would stop the engine completely. The expert says a completely shorted O2 sensor can keep the vehicle from running and recommends unplugging it as a test. The expert also advises checking for air leaks between the MAF and throttle bore and other vacuum leaks.
