I have a 1994 chevy 1500 4x4 v6 with just over 90000 miles, i just blew the rear brake line and replaced it when I tried to bleed them I get no pressure to the rear bleeders also when you pump the the pedal it stays hard and does not fall to the floor when you open the bleeders! Is there a special to bleed them I was told you have to hold in some pin on the abs block?
Oct 5, 2007 at 6:56 AM
