1993 Chevrolet Astro Indicator Misaligned
Suggested Repair
Locate the small gear-indicator cable running from the indicator to the bottom of the steering column and adjust it so the pointer lines up with the selected gear.
Conversation Summary
The owner of a 1993 Chevy Astro could not shift out of park. A broken shift-arm tension spring was replaced with one from a 1992 GMC Safari, and a brake-pedal vacuum switch whose contacts were not separating was adjusted so shifting worked again. Afterward the gear indicator was misaligned and the vehicle would not move when placed in gear. The owner asked whether removing the instrument panel would correct the indicator. The expert said the 1993 has a small cable from the indicator to the bottom of the column that is easy to adjust once found. The owner then asked about a clip, whether the cable commonly breaks, and whether one from a 1992 Safari with a digital dash could be used; those follow-ups were not answered.
