1998 Chevy Silverado Intake Backfire
LESLIE LABS
My son owns a 1998 Chevy Silverado 4x4 with a 350 A/c powersteering, etc.
The other day it would not start and acts as if it is "loading up" a cylinder with fuel and back firing through the intake.
At a Chevy Dealers direction we replaced the Fuel Pressure Regulator with no change in results. We checked the timing and it was correct, but even so we pulled off the front of the engine and the timing gears and chain were all good. Believing it may be a rounded lobe on the cam we turned the engine over with the valve covers removed and all the push rods are making a full travel.
Any help or suggestions would greatly be appreciated.
Feb 27, 2007 at 11:26 AM
CHEVY22
  • 1,375 POSTS
hi
i thiink
if you have good spark this could be the cam postion sensor , it geta a signal from crank sensor and ic module and times the injectors , if the cam sensor is failing there is a one in six chace the injectors will pulse the right cylinder ,, located under ign rotor on dist
did you have a light on , ??????????????????
jim
Feb 27, 2007 at 11:51 AM
Suggested Repair
If spark is good, check the camshaft position sensor under the distributor rotor. It uses crankshaft sensor and ignition control module signals to time the injectors; a failing sensor can pulse the wrong cylinder and cause intake backfire. Also note whether a warning light is on.
Conversation Summary
A 1998 Chevy Silverado with a 350 engine would not start, acted as if a cylinder was loading up with fuel, and backfired through the intake. The fuel pressure regulator was replaced with no change, timing and the timing chain were verified good, and all pushrods showed full travel. The expert suggested a failing camshaft position sensor if spark is good and asked whether a warning light was on.
