2002 Malibu Surging
LUANGTOM
  • 5 POSTS
I drive a 2002 Chevrolet Malibu with 69,XXX-miles
on it. At highway speeds, the engine rpm's "surge"
200-300-rpm's under no load. No "service engine"
lights or codes appear. We have serviced the fuel-
injectors, checked the plugs and wires and finally
replaced the fuel-injectors. We still get the "surge".
We also took out the K&N filter thinking it may have
contaminated the MAF sensor and replaced it with a
Fram paper-filter. We cleaned the MAF sensor and we
still get the "surge" Any suggestions? Should we now
replace the MAF sensor?
May 27, 2006 at 1:46 PM
SDALTON19
  • 87 POSTS
your problem could be a number of things however sometimes cleaning the maf sensor does no good depending on whether it is a hot film type or not if the maf sensor was contaminated with oil i would say it is best to replace it rather than clean it if you dont have any diagnostic equipment to properley test the sensor
May 27, 2006 at 2:11 PM
LUANGTOM
  • 5 POSTS
Thanks. We have changed all of the fuel-injectors,
checked the plugs and wires, all to no avail. We
just changed the Mass Air Flow sensor today. The
car still surges the 200-300 rpm's at highway speeds.
It does this maybe two or three times in 25-miles.
Any suggestions as to what we should try next????
May 30, 2006 at 5:30 AM
LUANGTOM
  • 5 POSTS
After running through all of the fuel-injector and
MAF sensor replacedment, we still have the surge.
We drove the car in D3 versus D/Over-drive and
the surge does not happen. Could this be slipping
in over-drive?
Jun 1, 2006 at 5:37 AM
