My lights will dim every once and a while and the interior lights also dim at the same time.The only the different that i have noticed is that the volt meter is running well above 14volts compared to what i am used to seeing it run at.Would you have any suggestions on what could be going on?At this time the truck is running fine but i do not want to wait for some thing major to happen before i do anything.
Dec 21, 2009 at 5:39 AM
