2000 Chevy Truck entended crank
TOMMYSCHNEIDER20
  • 2000 CHEVROLET TRUCK
  • V8
  • 4WD
  • 72,000 MILES
My Chevy 2500 HD Classic body style 4x4 with a 5.7 l. V8 has a very long crank time. Fuel pump died 18 months ago, I replaced it and the filter. Truck started great until a couple months ago. Crank time has grown longer and longer over the past couple months. I live in Michigan and the temp has gottten much cooler over the last couple months. I can hear the fuel pump running and stoping like it is suposed to. I cahanged cap and rotor, all plugs, and wires last week, no better on start. Changed crank sensor today, still have problem.
Saturday, January 2nd, 2010 AT 10:18 AM
JDL
  • 16,098 POSTS
Hi, use a gage and check fuel pressure. Sometimes, cycling the key several times before you crank, might help the fuel system, if the problem is a fuel issue? Engine cranking, the pump gets battery voltage. Engine running it gets alternator voltage, there is a difference. I guess you use a block heater?
Saturday, January 2nd, 2010 AT 10:43 AM
