2000 Chevy Malibu Coolant Leak
MADCAT424
  • 12 POSTS
I have a 2000 Chevy Malibu LS (V6) with 105k miles on it. I just recently have been having a problem with it. It seems that after I drive for awhile and then park it, it leaks out a TON of coolant from the vent tube on the expansion tank. I have replaced the water pump, radiator cap, intake manifold (that was also leaking) thermostat. It still leaks out there, and leaks almost all the coolant out everytime. The car never shows any signs of overheating, I check the gauge all the time. Any ideas, me and my father are completly stumped. Thanks.
Nov 8, 2006 at 8:01 PM
BUELLXB9RFB
  • 50 POSTS
kinda sonds like the radiator is clogging up . you might want to flush the entire system with a coolant flush real good . prolly needs it any way
Nov 9, 2006 at 1:20 AM
MADCAT424
  • 12 POSTS
Forgot to mention that I already flushed it, when I replaced the water pump.
Nov 9, 2006 at 6:39 AM
BOOTDOG
  • 665 POSTS
i hate to say it but its sounds like a blown head gasket. what is probably happening is that exhaust is getting into your coolant system forcing it out of your expansion tank. take it to someone who can propperly diagnose it.
Nov 10, 2006 at 2:09 AM
Suggested Repair
Have the cooling system professionally tested for a blown head gasket. Exhaust gas entering the coolant can pressurize the system and force coolant out of the expansion tank vent even when the temperature gauge stays normal. A flush and replacement of the water pump, radiator cap, intake manifold, and thermostat have not stopped the leak.
Conversation Summary
A 2000 Chevy Malibu LS V6 with 105,000 miles loses a large amount of coolant from the expansion tank vent tube after being driven and parked, without showing overheating. The owner already replaced the water pump, radiator cap, intake manifold, and thermostat and flushed the system. One reply suggested a clogged radiator and another flush, but the owner said that was already done. The expert said the symptoms sound like a blown head gasket allowing exhaust into the cooling system and recommended a proper diagnosis.
