1999 Chevy Truck oil change
RIDECU42
  • 1999 CHEVROLET TRUCK
  • V8
  • 4WD
  • 140,000 MILES
This has a 350 engine with the stock oil cooler in the radiator. I rebuilt the engine recently. When I first filled it with oil it took seven quarts. When I gave it the first oil change after 500 miles, only 5 1/2 quarts drained out. I imagine the other 1 1/2 quarts are in the oil cooler. I have two friends with similar trucks, and they say when they change oil it only takes 5 1/2 quarts too. How do I drain the oil from the oil cooler. Is everybody leaving 1 1/2 quarts of dirty oil in their trucks every oil change, or am I just crazy?
Thursday, February 5th, 2009 AT 10:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
That is correct. About 10% of the engine oil is still left in the cooler. Theoretically, the dirt should all be in the filter. The small amount of dirty "looking" oil left in the cooler should not have any contaminents in it that could damage your engine. However, I don't really believe this is true and I suggest flushing the cooler every oil change. It will cost a little extra but it is worth it in the long run. To flush the cooler, do the following.
Drain the old oil then pour in a couple of pints of new oil and turn engine over a few times (dont start it). Replace old oil filter after flushing cooler then fill with new oil.
Thanks for using 2CarPros. Com!
Friday, February 6th, 2009 AT 2:07 AM
RIDECU42
That, s amazing. Nobody else has ever been able to tell me this. Everybody out there with a truck like this should be mad as hell that this is not common knowledge. Every time that they have had their oil changed, whoever did it left 1 1/2 quarts of dirty oil in their engine. I have not heard of this, and I have been looking in forums like this for awhile now trying to address this problem. It is not in any manual that I have ever seen.
Friday, February 6th, 2009 AT 10:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yeah, it's pretty weird. I guess is because not all vehicle is equipped with the oil cooler and maybe other people just don't notice.
Friday, February 6th, 2009 AT 10:21 PM
