I have oil coming out of the vent tube on the front differential. No oil had been added before this problem started.
Thursday, February 22nd, 2007 AT 7:42 PM
CHEVY22
MECHANIC
Is the oil pumping out or just a small drip?
Oh I just remembered there is an updated tube assembly for this problem
SPONSORED LINKS
Thursday, February 22nd, 2007 AT 8:28 PM
AUSTS
MEMBER
The oil pumps out when it does it. It doesn't do it all the time. But when it does it soaks the driverside of radiator and steering gearbox. Thanks in advance for your help
Saturday, February 24th, 2007 AT 4:44 PM
CHEVY22
MECHANIC
I would suspect the check valve in the tube may have failed as I sated before, let me know if you need anymore help I get an email when the post is replied to
jim
Saturday, February 24th, 2007 AT 4:54 PM
AUSTS
MEMBER
Thanks for your help I will try this and let you know of the outcome
