1997 Chevy Truck V8 Two Wheel Drive Automatic
I have a problem with my cooling system on my truck it has started running hot on me so I replaced the thermastat on it and the water pump and pulled the radiatior and did a water hose flush on it and it ran through fine but it is still running hot, the radaitor is hot on one side but cold on the other side and water is passing through the block and there is no leaks on it at all what can I do to make it stop running hot ;please help;
kandi
SPONSORED LINKS
Monday, August 18th, 2008 AT 12:48 PM
