1996 Chevy Truck hard to start some times
1996 CHEVROLET TRUCK
70,000 MILES • V8 • 4WD • AUTOMATIC
DAVEW741
  • 5 POSTS
sometimes when i try to start my truck it starts hard, but then sometimes its fine. it tunn over hard like a dead battery the starter is brand new and so it the battery so its not the starter or battery. the fuel injectors are two years old and the reading that i get from the computor says catalists under efficiency. but then sometimes it says missfire on number 3 cyl. what would make it hard to crank over sometimes? the missfire on number 3 only come when it hard to start but then i do get it to start thank you
Jan 5, 2008 at 11:23 PM
DAVEW741
  • 5 POSTS
[quote:d39a530dc7="davew741"]Engine problem
1996 Chevy Truck V8 Four Wheel Drive Automatic 70000 miles
sometimes when i try to start my truck it starts hard, but then sometimes its fine. it tunn over hard like a dead battery the starter is brand new and so it the battery so its not the starter or battery. the fuel injectors are two years old and the reading that i get from the computor says catalists under efficiency. but then sometimes it says missfire on number 3 cyl. what would make it hard to crank over sometimes? the missfire on number 3 only come when it hard to start but then i do get it to start thank you[/quote:d39a530dc7] thank you very much
Jan 19, 2008 at 8:42 PM
DAVEW741
  • 5 POSTS
[quote="davew741"][quote:5289fa5acd="davew741"]Engine problem
sometimes when i try to start my truck it starts hard, but then sometimes its fine. it tunn over hard like a dead battery the starter is brand new and so it the battery so its not the starter or battery. the fuel injectors are two years old and the reading that i get from the computor says catalists under efficiency. but then sometimes it says missfire on number 3 cyl. what would make it hard to crank over sometimes? the missfire on number 3 only come when it hard to start but then i do get it to start thank you[/quote:5289fa5acd]
Jan 19, 2008 at 8:44 PM
MASTERTECHTIM
  • CERTIFIED EXPERT
  • 4,750 POSTS
sorry guy there are 25 of us answering questions and thousands of questions. sounds like to me you have a bad fuel pressure regulator inside your plenom or the #3 injector is bleeding down. hope this helps :wink:
Jan 19, 2008 at 8:46 PM
DAVEW741
  • 5 POSTS
[quote:38826feecb="mastertechtim"]sorry guy there are 25 of us answering questions and thousands of questions. sounds like to me you have a bad fuel pressure regulator inside your plenom or the #3 injector is bleeding down. hope this helps :wink:[/quote:38826feecb] thank you very much that will help me
Jan 21, 2008 at 7:29 PM
