1996 Chevy Truck Front wheel bearings
140,000 MILES • V8 • 2WD • AUTOMATIC
KEJOBU2
My left front wheel outer bearings are tore up. I removed the caliper and rotor but how do I get the inner bearing off. Could it have damaged the spindle? it is tapered but i'm not sure how it is supposed to look.
Feb 2, 2009 at 9:25 AM
2CARPRO JACK
  • 11,533 POSTS
If the inner bearing is stuck to the spindle, you may have to try to drive it off with a punch. If it got so bad that it welded itself to the spindle, you may have to replace it
Feb 2, 2009 at 12:27 PM
