1996 Chevy Truck four wheel drive
90,000 MILES • V8 • 4WD • AUTOMATIC
CMICHAEL
my truck wont engage in four wheel drive it keeps blowing the fuse
Mar 4, 2008 at 6:22 AM
MASTERTECHTIM
  • 4,750 POSTS
hop under the front of the truck and unplug the front diff actuator. there are 2 electrical plugs on the front diff, if you are unsure then unplug both of them. install new fuse and shift into 4wd, if the fuse does not blow then replace the front diff actuator(this is common problem for blowing the fuse) hope this helps
Mar 4, 2008 at 6:41 AM
