1995 Chevy Truck LOPES AT IDLE
MINDBAKIN
  • 1995 CHEVROLET TRUCK
Engine Mechanical problem
1995 Chevy Truck 6 cyl Four Wheel Drive Automatic? Miles
Idles at 550-600 rpms lopes with ruff idle then you get to 900 and above it runs fine untill you come to a stop. Then repeats. Any suggestions
Saturday, October 16th, 2010 AT 12:24 PM
HMAC300
  • 48,601 POSTS
Try spraying choke cleaner on your throttle plate and idle air control (oblong hole) it may be partially clogged with oil an dgunk. Make sure to apray on both sides. Engine may be hard to start after doing this however. It may cure it but also check vacuum hoses for soft and leakage.
Monday, October 18th, 2010 AT 7:18 PM
