Engine won`t Idle when I put it in gear, Shuts down and then its hard to restart. I thought it was a vaccum hose that came off.but I found nothing.also I changed the cap,rotor,wires and plugs about 3 monthes ago. and had a new gas tank, sending unit,gas lines and filter replaced about 4 monthes ago.only thing else I can think of is the EGR Valve. What do you guys recomend? thankyou
Jan 22, 2010 at 7:24 PM
