1994 Chevy Truck spark plug blew out porcelain while runnin
MIKEPAUL
  • 1994 CHEVROLET TRUCK
1994 Chevy Truck 6 cyl Four Wheel Drive Manual
spark plug blew out porcelain while running
what would cause this?
Friday, October 10th, 2008 AT 5:45 PM
BLACKOP555
  • 10,371 POSTS
Did the plug blow out of the hole/
check to see if the bridge of the spark plug is bent or the plug is damaged, such as being struck by a piston.
If no damage is noted chances are the porcelain was poor, dropped and then later it cracked due to normal operating conditions.
Friday, October 10th, 2008 AT 7:28 PM
SWILLIAMS
  • 597 POSTS
To add a few others I have seen a few plugs with very poor crimps to retain the porcelain and even a couple that were not crimped at all!
Monday, October 13th, 2008 AT 5:50 PM
BLACKOP555
  • 10,371 POSTS
Very possible as swilliams says.
Basically just check to see if the porcelain is still in the plugs, if theres no porcelain at all probably a poor crimp.
Monday, October 13th, 2008 AT 6:07 PM
