1994 Chevy Suburban, automatic, 220k miles. Suddenly speedometer doesnt work, and ABS light comes on after vehicle rolls. 1st and second gears work when shifted manually, but drive and overdrive act as 1st gear. Also happened a couple weeks ago after an interior shampoo, but went away. Probobly got electronics wet somewhere. Codes say "speed control" and "brake switch stuck off." I'm about to replace the speed control, but it seems that's just temporarily fixing one of the symptoms. I cant drive faster then second gear and need help asap. Thank you! :Cry:
SPONSORED LINKS
Tuesday, September 12th, 2006 AT 9:44 AM
