1990 Chevy Truck Truck sputters and dies
1990 CHEVROLET TRUCK
324,000 MILES • V8 • 2WD • AUTOMATIC
PMANTECH
My truck will crank but right after sputters then dies. I can work the pedel to keep it running but its sputtering the whole time. Replaced map sensor but no change. Any suggestions???
Dec 2, 2009 at 7:03 AM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Has the check engine light come on? Have you checked fuel pump pressure? Here is a how to for checking fuel pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find. Also, check for vacuum leaks.
Dec 22, 2009 at 10:19 AM
