1990 Chevy Truck fuel lines
134,000 MILES • V8 • 4WD • AUTOMATIC
JOTHRE
The fuel line is leaking in the truck between the gas tank and the first coupling. The coupling is rusted together and I have used PB Blaster on it for two days and it still won't come apart. Do you have any suggestions?
Oct 14, 2010 at 5:10 AM
JDL
  • 16,098 POSTS
Maybe you can replace the coupling also? If the autostore or dealership can't help, maybe you find it at the salvage yard?
Oct 14, 2010 at 5:24 AM
WRENCHTECH
  • 20,760 POSTS
You may have to replace the both lines if you can't get it apart.
