1990 Chevy Truck backfiring
CHIZELLE1
  • 1990 CHEVROLET TRUCK
Engine Mechanical problem
1990 Chevy Truck V8 Two Wheel Drive Automatic
when I try to start it, it will start, run and idle until I cut it off, then it won't start again and it seems like the exhaust is getting clogged up and it backfires really bad. What could be causing that?
Sunday, February 22nd, 2009 AT 8:36 PM
BMRFIXIT
  • 19,053 POSTS
Check it for tune up
check coil
Sunday, February 22nd, 2009 AT 9:03 PM
CHIZELLE1
I have already done a tune up, replaced the oxygen sensor, and the pcv valve. It seems to clog up after running for a while and then starts backfiring. If I turn it off, it won't start again. Any other ideas?
Sunday, February 22nd, 2009 AT 9:10 PM
BMRFIXIT
  • 19,053 POSTS
Check the COIL
do a fuel test
check EGR valve
Sunday, February 22nd, 2009 AT 9:54 PM
