1989 Chevy Truck
1989 CHEVROLET TRUCK
TRIPP86
Drive Train Axles Bearings problem
1989 Chevy Truck V8 Four Wheel Drive Automatic
just wondering if any1 has an exploded vies of an 89 chev k1500 front differential. i'm leaking fluid from the flange where u bolt the front drive axle to. on the driver side (no axle tube assembly). also if i have to open the diff up or if i can just change it from the flange? thanks
Jul 5, 2009 at 8:32 AM
DR LOOT
  • 2,311 POSTS
you should be able to just change the flange, but I suggest you go purchase yourself a manual, to give you a heads up on dis assembly and assembly because it's too much to talk about.
Jul 10, 2009 at 3:15 PM
