Blower works on high
1985 CHEVROLET TRUCK
10,000 MILES • V8 • 4WD • AUTOMATIC
SUDSY74
hello great web site . i have a 85 chevy scottsdale. when i turn on the switch to operate the heater or a/c it only works on high. i replaced the blower and the switch in the cab. what else would cause the fan to blow only on high and not on low or medium. thanks for your help scott
Aug 17, 2009 at 6:19 PM
  • CERTIFIED EXPERT
  • 53,902 POSTS
It sounds like the blower motor resistor has gone out but to be sure lets test the system. Here is a blower motor wiring diagram and guide so you can do some testing.
Check to see it losses power here are the diagram (Below)
Cheers, Ken
Nov 17, 2017 at 7:17 PM
