1961 Chevy Truck Harmonic Balancer
3,000 MILES • V8 • 2WD • AUTOMATIC
DENBLAIR
I recently bought some alluminum pulleys to dress up my 350 small block engine, I installed a new thwater pump pulley, and the lower crank pulley. After starting up the engine I noticed that the harmonic balancer had a slight wobble to it from front to back about an eighth of an inch, I have never noticed this before and wondered if there is any amount of wobble in the balancer that is exceptable?
Mar 4, 2009 at 2:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If the elastomer wears out than the outer ring can move. However, a slight wobble is somewhat common but if it gets excessive than it can cause drive belt issues.
Thanks for using 2CarPros.com!
Mar 4, 2009 at 2:53 AM
