2007 Chevy Trailblazer possesed trailblazer
2007 CHEVROLET TRAILBLAZER
61,000 MILES • 6 CYL • 4WD • AUTOMATIC
EBROWN1975
sometimes I go out to start my vehicle and there's nothing there. totally dead no lights and no response to the key at all. The key wont even release from the ignition when this happens. after several attempts it usually starts and runs fine but i notice that when this happens my stereo is reset to 12 o'clock.
Jun 19, 2010 at 2:48 AM
FACTORYJACK
  • 4,159 POSTS
Have you checked first of all the cleanliness and tightness of the battery connections.
Jun 19, 2010 at 11:28 AM
EBROWN1975
Yes, I checked the terminals for tightness and cleaned/replaced and grounds that showed any signs of corrosion. had the battery and charging systems tested and all was fine
Jun 21, 2010 at 2:18 AM
FACTORYJACK
  • 4,159 POSTS
You have got to have a loss of power, or poor connection somewhere close to the battery. How often does this occur? If the clock is losing power, the radio is losing it's constant source. When it happens, check with a test light that you have power to the stud at the underhood fuse block from the battery. If you have power at the stud, and it is still acting up, bang on the underhood electrical center and see if something happens. It looks like all power is distributed from the underhood fuse block. Check the connections, possibly disconnect and reconnect the harness connectors, and if the harness connectors are held by bolts, make sure they are tight.
Jun 22, 2010 at 4:58 PM
