If the ABS Light and the Brake Light stay on, then the AC won't come on. Sometimes after driving for a while, these lights will go off and the AC will kick on.
I took it to the shop and they did a scanner test and then reprogrammed the Body Control module. It worked for a couple of days and then same thing started happening again.
I took it back to the shop and they did another scanner test and then REPLACED the Body Control Module. It worked for a couple of days and then same thing started happening again.
I took it back to the shop and they looked at it and said I had blown a fuse. Again, it worked for a couple of days and then the same thing IS HAPPENING AGAIN !
Please Help ! I am out $500 and still have the same problem that I went into the shop with. They don't seem to know what to do next.
Thanks for your help ! LBC
SPONSORED LINKS
Saturday, May 31st, 2008 AT 9:09 AM
