2002 Chevy Trailblazer Axle shaft bearing removal
97,000 MILES • 6 CYL • 4WD • AUTOMATIC
BMANTLOW
Is there a lock/clip inside the differential that has to be removed to pull the axle out and replace bearing?
Jan 20, 2009 at 9:29 AM
MERLIN2021
  • 17,250 POSTS
Here is all you need for that repair, this site has done a GREAT JOB! for this repair.
https://www.2carpros.com/articles/rear-axle-seal-replacement
Jan 20, 2009 at 9:39 AM
BMANTLOW
I'm sorry Merlin, I guess I didn't specify which differential.
My question is for the rear drive axles.
Jan 21, 2009 at 3:01 AM
MERLIN2021
  • 17,250 POSTS
In that case, at the rear, remove the cover, and pray it's not a limited slip(posi) unit. if not, you will see the ring gear and carrier, rotate it until you find the small bolt with the 5/16th head and remove it, slide out the center pin, after it's out DO NOT spin either wheel, push the axle inward at the wheel end, the clip can be rmoved now, if it doesnt fall out, then slide the axle out, use a slide hammer with the propper side bearing remover and remove the bearind...
Jan 22, 2009 at 10:32 PM
