1999 Chevrolet Tahoe Front Door Locks
LEECOGA
1999 Chevrolet Tahoe 4D 4WD 350 automatic 120K miles:
Both front door locks are working intermittently when triggered both by keyless remote and door switch. When lock/ unlock buttons are mashed repeatedly door lock mechanism becomes weaker and less responsive to the point of not moving at all. Rear doors work fine. Both door lock actuators and door lock relay switch have been replaced. Any advice would be appreciated.
Jun 14, 2007 at 2:20 PM
GOBOLTS
[quote:f8ded79d1c="leecoga"]1999 Chevrolet Tahoe 4D 4WD 350 automatic 120K miles:
Both front door locks are working intermittently when triggered both by keyless remote and door switch. When lock/ unlock buttons are mashed repeatedly door lock mechanism becomes weaker and less responsive to the point of not moving at all. Rear doors work fine. Both door lock actuators and door lock relay switch have been replaced. Any advice would be appreciated.[/quote:f8ded79d1c]
Jan 18, 2008 at 8:00 PM
DWB812
  • 108 POSTS
Are you sure you replaced the main door lock module? It really sounds like an intermitent main control module for the lock system. I think they are all located above the park brake lever up to 1999. Flat black box and I have installed replacements that were bad right out of the box. Probably a unit that had been installed by someone else, ruined, and returned. It's a possibility.
Jan 30, 2011 at 9:26 AM
Suggested Repair
Inspect or replace the main door lock control module, a flat black box located above the park brake lever on models through 1999. Confirm any replacement is not defective out of the box, since returned units can fail immediately.
Conversation Summary
The owner of a 1999 Chevrolet Tahoe reports both front door locks work intermittently from the keyless remote and door switches, becoming weaker until they stop after repeated use. Rear locks work normally, and the actuators and door lock relay have already been replaced. The expert suspects an intermittent main door lock control module above the park brake lever and notes that some replacements can be bad out of the box.
