Suv, tahoe, 01,134300, 5.3
the noise happanes when the fan for a/c is on. Its does not matter whether the a/c switch is on. Just that the fan switch is on. It happens sitting in park or nutreral reving the engine or going down the the road.A/c belt was taken loose and engine started so a/c comp was isolated from the system, and fan switch inside car was agin turned on and noise is still present when fan switch is turned on. Could this noise be from radiator cooling fan cluth going bad and or computer doing something to the system or what. Any help is much apreciated thanks
SPONSORED LINKS
Friday, June 8th, 2007 AT 8:35 AM
