1996 Chevy Tahoe ECM Shutdown
CHRISG
5.7 liter
4x4
4dr
gas engine
110,000 miles
Hello, i'm having a problem with my trucks ECM.
recently i had a fuel pump replaced. i drove the truck for a month with no problems. this past Sunday the truck would not start at all. i had it towed to a repair shop and they told me they had to replace the fuel pump again. so they replaced the pump again under warranty and also the crank shaft position sensor.
i got the truck back and the same day went food shopping. returning home the truck shut down on me several times. i managed to get the truck back to the repair shop and they checked it out for me again and told me that the problem is the ECM computer. they say that when the truck is driven the computer gets hot and shuts the vehicle down.
okay, i know i must replace the ECM but the service number has been ripped off of the ECM. i tried to get the part with out the ECM numbers but parts stores tell me that there is nothing i can do with out the service number of the ECM.
i wanted to know if there is any other way i can get the service number so i can order the correct ECM for my truck?
Jun 20, 2007 at 5:20 AM
FISHHEAD1955
I have had the same problem with my 1999 Tahoe.
Replaced:
Mass air flow sensor
Cam and crank speed sensors
Computer
Distributor complete
Fuel pump
Fuel filter
Fuel sensor
Idle speed sensor
I have check all of my grounds, battery, and charging system, all OK
And I still have the same problem,
Check spark when it starts to shut down. My Tahoe still loses spark when it starts to shut off.
After market alarm ?
After market stereo ?
If you find any info please let me know. Thanks
Aug 2, 2007 at 3:26 PM
2CARPRO JACK
  • 11,533 POSTS
Might want to try an ignition module. Sometimes when they get hot, they will short out.
Aug 3, 2007 at 12:54 AM
PEAR69
  • 1,482 POSTS
[quote:6536f99728="chrisg"]1996
chevy tahoe
5.7 liter
4x4
4dr
gas engine
110,000 miles
hello im having a problem with my trucks ecm.
recently i had a fuel pump replaced. i drove the truck for a month with no problems. this past sunday the truck would not start at all. i had it towed to a repair shop and they told me they had to replace the fuel pump again. so they replaced the pump again under warranty and also the crank shaft position sensor.
i got the truck back and the same day went food shopping. returning home the truck shut down on me several times. i managed to get the truck back to the repair shop and they checked it out for me again and told me that the problem is the ecm computer. they say that when the truck is driven the computer gets hot and shuts the vechicle down.
ok, i know i must replace the ecm but the service number has been ripped off of the ecm. i tried to get the part with out the ecm numbers but parts stores tell me that there is nothing i can do with out the service number of the ecm.
i wanted to know if there is any other way i can get the service number so i can order the correct ecm for my truck?[/quote:6536f99728]
Is this problem fixed?
Nov 1, 2007 at 5:37 PM
2CARPRO JACK
  • 11,533 POSTS
You can try using your VIN# at the dealer.
Nov 2, 2007 at 12:21 AM
Just to add to the idea of how you know which engine control module to order if your tag with the part number is no longer there. Not only can you go to a dealer and provide your VIN and they will be able to look it up but there are websites that provide the same service. Also, the ECM on these vehicles were not VIN specific, they were build specific, so if you find a vehicle that is equipped the same then you can pull the part number from that module. However, the issue with this option is unless you are able to confirm the vehicle is equipped the same (power-train) you may not get the correct part number.
Clearly the best option is to consult a dealer and allow them to provide the correct part based on your VIN.
Mar 23, 2020 at 9:55 AM
Suggested Repair
Use the vehicle VIN at a Chevrolet dealer to identify the correct ECM, since the service tag is missing. Also consider the ignition control module, which can fail when hot and shut the engine down.
Conversation Summary
A 1996 Chevrolet Tahoe 5.7L began stalling after a second fuel pump and crankshaft position sensor replacement. A shop blamed a heat-related ECM failure, but the ECM service number was missing. Experts advised identifying the correct module with the VIN at a dealer and suggested checking the ignition module, which can short when hot.
