2005 Chevy Tahoe CLUNK NOISE
2005 CHEVROLET TAHOE
96,000 MILES • V8 • 4WD • AUTOMATIC
TAHOE123456
I have an 05 Tahoe Z71 that still clunks in the front end at low speed on rough roads. I have had the intermediate shaft replaced with the updated version and also had the lower steering shaft bearing replaced but the clunking noise is still there. Any suggestions?
Apr 13, 2009 at 5:34 AM
BRIAN 1
  • 1,030 POSTS
does this vehicle have running boards? if it does remove them and see if the noise goes away.if it does not have running boards,have had alot of problems with the body mounts.there are isulators that go inbetween the mounts.try the above first and post back on how you make out.
Apr 13, 2009 at 6:05 AM
