2005 Chevy Tahoe
2005 CHEVROLET TAHOE
WILLIE HANKS
Air Conditioning problem
2005 Chevy Tahoe V8 Two Wheel Drive Automatic
My truck has front and rear air conditioning and the front is not blowing but the back is. What is the reason for the front to stop blowing and what kind of action I need to take to get this problem resolved?
Aug 1, 2010 at 5:44 PM
EDWARD.S
  • 166 POSTS
Hi,First I'd check the heater /ac Fuse.If It's Good .I'd Check For voltage At The blower Motor.This can be done with a test light.if you have power and ground at the blower motor, then you need to replace it.
Hope This Helps You,
Good Luck
Edward S.
Aug 1, 2010 at 5:58 PM
