The problem started while driving in rush hour traffic. The truck started to stall, pushing the gas pedal would not initially respond. The engine would finally respond after several seconds. Once the car cools down it runs fine. I have replace the fuel filter, 3 pumps ( last one was an AC Delco) relay switch fuel injectors cleaned and a new wiring harness.
I am at a loss at where to look next. Everyone says that it sounds like vapor lock, the only problem is that it is fuel injected.
SPONSORED LINKS
Thursday, May 29th, 2008 AT 7:18 PM
